メインコンテンツにスキップ
Acer Aspire E5-571 CPU Fan Replacement
必要な工具と部品
  1. Acer Aspire E5-571 CPU Fan Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 CPU Fan Replacement: 手順 2、 1の画像 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 CPU Fan Replacement: 手順 3、 1の画像 1
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 CPU Fan Replacement, Keyboard: 手順 4、 1の画像 1
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 CPU Fan Replacement: 手順 5、 3の画像 1 Acer Aspire E5-571 CPU Fan Replacement: 手順 5、 3の画像 2 Acer Aspire E5-571 CPU Fan Replacement: 手順 5、 3の画像 3
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips. Do not remove the keyboard until told to do so.
  6. Acer Aspire E5-571 CPU Fan Replacement: 手順 6、 2の画像 1 Acer Aspire E5-571 CPU Fan Replacement: 手順 6、 2の画像 2
    • Carefully flip up the white hinge. Then, detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
  7. Acer Aspire E5-571 CPU Fan Replacement, WiFi: 手順 7、 1の画像 1
    • Locate the WiFi card on the motherboard.
  8. Acer Aspire E5-571 CPU Fan Replacement: 手順 8、 2の画像 1 Acer Aspire E5-571 CPU Fan Replacement: 手順 8、 2の画像 2
    • Locate the two antenna cables shown.
    • Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
    • Black on left. White on right.
  9. Acer Aspire E5-571 CPU Fan Replacement: 手順 9、 3の画像 1 Acer Aspire E5-571 CPU Fan Replacement: 手順 9、 3の画像 2 Acer Aspire E5-571 CPU Fan Replacement: 手順 9、 3の画像 3
    • Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
    • Make sure antenna cables are removed before removing the screw.
    • Gently lift WiFi card off of the motherboard.
  10. Acer Aspire E5-571 CPU Fan Replacement, CPU Fan: 手順 10、 1の画像 1
    • Locate the CPU Fan in the case right above the motherboard.
  11. Acer Aspire E5-571 CPU Fan Replacement: 手順 11、 1の画像 1
    • Detach the power cable by carefully pulling on it, it will come off easily.
  12. Acer Aspire E5-571 CPU Fan Replacement: 手順 12、 1の画像 1
    • Remove both of these 6 mm Phillips #1 screws which hold the fan onto the case.
    • Now carefully lift the fan straight up and out of its place in the case.
    • The fan should easily come right out with no trouble.
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
daniel sawyer
メンバー登録日: 08/23/15
2,566 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 4-2, Meier Fall 2015 USF Tampa, Team 4-2, Meier Fall 2015人のメンバー
USFT-MEIER-F15S4G2
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 21
今までの合計 4,314
