メインコンテンツにスキップ
Acer Aspire E5-471-5456 USB Port Replacement
必要な工具と部品
  1. Acer Aspire E5-471-5456 USB Port Replacement, Back Cover: 手順 1、 2の画像 1 Acer Aspire E5-471-5456 USB Port Replacement, Back Cover: 手順 1、 2の画像 2
    • Carefully place the closed computer on a flat surface, with it oriented screen down.
    • Now you need to use the Phillips #0 Screwdriver to remove all 17 of the M2.5X8 mm screws. Use the red circles on the diagram to help you locate these screws.
  2. Acer Aspire E5-471-5456 USB Port Replacement: 手順 2、 2の画像 1 Acer Aspire E5-471-5456 USB Port Replacement: 手順 2、 2の画像 2
    • Use an opening tool to gently pry open the case.
    • Take extreme care when removing the case to not get the case stuck on any of the ports. Make sure that to evenly open the case and not pry one side open before the other to avoid damage.
    • Slowly peel the cover off and make sure there are no wires or clips still connecting the two pieces together. These pieces are extremely fragile so it is vital to take your time and only use light pressure.
  3. Acer Aspire E5-471-5456 USB Port Replacement: 手順 3、 1の画像 1
    • Place cover and screws aside and you are now free to access the different components of this laptop.
  4. Acer Aspire E5-471-5456 USB Port Replacement, USB Port: 手順 4、 2の画像 1 Acer Aspire E5-471-5456 USB Port Replacement, USB Port: 手順 4、 2の画像 2
    • Locate the two USB ports in the bottom corner of the laptop.
    • Use a screwdriver to take out the M2X3 mm screw located in the orange circle. For an easier reassembly, take note that the USB port has a white arrow that indicates which  orange hole the screw should be returned to.
  5. Acer Aspire E5-471-5456 USB Port Replacement: 手順 5、 2の画像 1 Acer Aspire E5-471-5456 USB Port Replacement: 手順 5、 2の画像 2
    • Remove the cable (look for the one with a blue tag reading "USB") very carefully as it is fragile by using the opening tool.
  6. Acer Aspire E5-471-5456 USB Port Replacement: 手順 6、 1の画像 1
    • The USB ports should now be able to be removed from the laptop, carefully.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Justin Saeidian
メンバー登録日: 09/26/17
273 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S6-G4, Banghart Fall 2017 Cal Poly, Team S6-G4, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S6G4
5 メンバー
6のガイドは作成済み
コメント 1 件
where can i purchase the port
Jermian Francis - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 18
今までの合計 1,944
