はじめに
This guide will help you replace the touchpad on your computer.
必要な工具と部品
Insert your plastic opening tool between the bottom case and the rest of the laptop.
Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
Lift the bottom off the laptop.
Lift up on the black tab to release the ribbon cable from the touchpad.
Lightly pull on the blue tab to remove the cable from the connector.
ある他の人がこのガイドを完成しました。
