メインコンテンツにスキップ
Acer Aspire E3-111-C0WA Touchpad Replacement
必要な工具と部品
  1. Acer Aspire E3-111-C0WA Touchpad Replacement, Battery: 手順 1、 2の画像 1 Acer Aspire E3-111-C0WA Touchpad Replacement, Battery: 手順 1、 2の画像 2
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 2、 3の画像 1 Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 2、 3の画像 2 Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 2、 3の画像 3
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 3、 2の画像 1 Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    購入する
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 4、 3の画像 1 Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 4、 3の画像 2 Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 4、 3の画像 3
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 5、 2の画像 1 Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 5、 2の画像 2
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 6、 2の画像 1 Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 6、 2の画像 2
    • Lift the battery up and off the rest of the laptop.
  7. Acer Aspire E3-111-C0WA Touchpad Replacement, Touchpad: 手順 7、 2の画像 1 Acer Aspire E3-111-C0WA Touchpad Replacement, Touchpad: 手順 7、 2の画像 2
    • Lift up on the black tab to release the ribbon cable from the touchpad.
    • Lightly pull on the blue tab to remove the cable from the connector.
  8. Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 8、 2の画像 1 Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 8、 2の画像 2
    • Peel up the silver tape adhering the touchpad cable to the case, revealing two screws underneath.
  9. Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 9、 2の画像 1 Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 9、 2の画像 2
    • Unscrew the three 6.2mm Phillips #1 screws holding the touchpad to the case.
  10. Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 10、 3の画像 1 Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 10、 3の画像 2 Acer Aspire E3-111-C0WA Touchpad Replacement: 手順 10、 3の画像 3
    • Lift the touchpad assembly out of the case by its corners.
    • Slide the touchpad out of the chassis from under the speaker cable, taking care not to damage the cable.
    • Check to make sure the small strip of conductive tape connecting the copper pad on the PCB to the metal assembly is properly adhered.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Jonathan Chandler
メンバー登録日: 10/17/17
503 ポイント
4のガイドは作成済み
チーム
UC Santa Barbara, Team S1-G2, Weedon Fall 2017 UC Santa Barbara, Team S1-G2, Weedon Fall 2017人のメンバー
UCSB-WEEDON-F17S1G2
5 メンバー
5のガイドは作成済み
コメント 1 件
Well made instruction, presumably works on all E3-111 devices; it did on my E3-111-C45G.
The spare parts number (Europe) is Acer No. TAA4329129, dubbed “Original Acer Touchpad / Touchboard silver Aspire E3-11 series”. Should cost around 22-25€.
ce re - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 12
今までの合計 963
