メインコンテンツにスキップ
Acer Aspire E3-111-C0WA Hard Drive Replacement
必要な工具と部品
  1. Acer Aspire E3-111-C0WA Hard Drive Replacement, Battery: 手順 1、 2の画像 1 Acer Aspire E3-111-C0WA Hard Drive Replacement, Battery: 手順 1、 2の画像 2
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA Hard Drive Replacement: 手順 2、 3の画像 1 Acer Aspire E3-111-C0WA Hard Drive Replacement: 手順 2、 3の画像 2 Acer Aspire E3-111-C0WA Hard Drive Replacement: 手順 2、 3の画像 3
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA Hard Drive Replacement: 手順 3、 2の画像 1 Acer Aspire E3-111-C0WA Hard Drive Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    購入する
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA Hard Drive Replacement: 手順 4、 3の画像 1 Acer Aspire E3-111-C0WA Hard Drive Replacement: 手順 4、 3の画像 2 Acer Aspire E3-111-C0WA Hard Drive Replacement: 手順 4、 3の画像 3
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA Hard Drive Replacement: 手順 5、 2の画像 1 Acer Aspire E3-111-C0WA Hard Drive Replacement: 手順 5、 2の画像 2
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA Hard Drive Replacement: 手順 6、 2の画像 1 Acer Aspire E3-111-C0WA Hard Drive Replacement: 手順 6、 2の画像 2
    • Lift the battery up and off the rest of the laptop.
  7. Acer Aspire E3-111-C0WA Hard Drive Replacement, Hard Drive: 手順 7、 2の画像 1 Acer Aspire E3-111-C0WA Hard Drive Replacement, Hard Drive: 手順 7、 2の画像 2
    • Holding the laptop in place, slide the hard drive horizontally out from the SATA connector.
終わりに
作成者
1人の作成者と共同作成されました。
Jonathan Chandler
メンバー登録日: 10/17/17
503 ポイント
4のガイドは作成済み
チーム
UC Santa Barbara, Team S1-G2, Weedon Fall 2017 UC Santa Barbara, Team S1-G2, Weedon Fall 2017人のメンバー
UCSB-WEEDON-F17S1G2
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 10
今までの合計 595
