はじめに
The keyboard and touchpad are the main input devices in the Acer Aspire E1-572-6829 laptop. If these devices are malfunctioning and none of the steps listed in our troubleshooting guide helps you fix it, you might have to replace these components.
The keyboard and touchpad assembly in this laptop consists of the entire top panel that needs to come off before you can access the motherboard and other internal components of the laptop. This guide will help guide through the steps required to disassemble and replace the top panel assembly in the Acer Aspire E1-572-6829.
Make sure that your device is powered off and the charger is unplugged before beginning the steps in this guide.
必要な工具と部品
Flip the laptop over so that you are facing the back panel.
Locate the battery lock switch below the battery.
Use a Phillips #0 screwdriver to remove the seventeen 8 mm screws that secure the back panel.
Use a plastic spudger to pry open the lower back panel from its top edge.
Lift the panel up and out to remove it.
