はじめに
If you feel your Acer Aspire E1-572-6829 overheating, there might be a problem with your laptop's fan. This guide explains how to replace the fan in your laptop. Take a look at our troubleshooting page to see if there are any other fixes you can make before taking these steps to replace your fan.
The fan in your Acer Aspire E1-572-6829 works to cool off your laptop as the other components of your laptop generate heat. If your laptop is overheating and you have already checked for improper ventilation and a dying battery, then you should consider replacing the fan in your laptop. Follow these steps to replace a broken Acer Aspire E1-572-6829 fan.
Make sure that your device is powered off and the charger is unplugged before beginning the steps in this guide.
必要な工具と部品
Flip the laptop over so that you are facing the back panel.
Locate the battery lock switch below the battery.
Use a Phillips #0 screwdriver to remove the seventeen 8 mm screws that secure the back panel.
Use a plastic spudger to pry open the lower back panel from its top edge.
Lift the panel up and out to remove it.
