メインコンテンツにスキップ
Acer Aspire E1-531-2438 Wifi Card Replacement
必要な工具と部品
  1. Acer Aspire E1-531-2438 Wifi Card Replacement, Battery: 手順 1、 2の画像 1 Acer Aspire E1-531-2438 Wifi Card Replacement, Battery: 手順 1、 2の画像 2
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 Wifi Card Replacement: 手順 2、 1の画像 1
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 Wifi Card Replacement, WiFi Card: 手順 3、 2の画像 1 Acer Aspire E1-531-2438 Wifi Card Replacement, WiFi Card: 手順 3、 2の画像 2
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
  4. Acer Aspire E1-531-2438 Wifi Card Replacement: 手順 4、 3の画像 1 Acer Aspire E1-531-2438 Wifi Card Replacement: 手順 4、 3の画像 2 Acer Aspire E1-531-2438 Wifi Card Replacement: 手順 4、 3の画像 3
    • Using the indentation, pry open the access panel with your fingers or a spudger.
    • Remove the access panel to expose the hard drive, WiFi card, and RAM modules.
  5. Acer Aspire E1-531-2438 Wifi Card Replacement: 手順 5、 1の画像 1
    • Using a spudger, disconnect the two antenna cables connectors on the WiFi card.
  6. Acer Aspire E1-531-2438 Wifi Card Replacement: 手順 6、 2の画像 1 Acer Aspire E1-531-2438 Wifi Card Replacement: 手順 6、 2の画像 2
    • Using a Phillips #0 screwdriver, remove the 3mm screw holding the WiFi card in place.
    • The card will then lift up after the screw is removed.
    • Remove the card by pulling out in the direction that the card is now orientated.
終わりに
作成者
2人の作成者と共同で作成されました。
Jakob Rinkus
メンバー登録日: 03/21/19
965 ポイント
7のガイドは作成済み
チーム
UMass Dartmouth, Team S8-G2, Bailey Spring 2019 UMass Dartmouth, Team S8-G2, Bailey Spring 2019人のメンバー
UMASSD-BAILEY-S19S8G2
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 920
