メインコンテンツにスキップ
Acer Aspire E1-510P-4637 Touch Screen Display Replacement
必要な工具と部品
  1. Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Battery: 手順 1、 1の画像 1
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 手順 2、 1の画像 1
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: 手順 3、 3の画像 1 Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: 手順 3、 3の画像 2 Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: 手順 3、 3の画像 3
    • Remove the plastic screw covers located near the laptop's hinge using a metal spudger.
    • Remove the two M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  4. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 手順 4、 3の画像 1 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 手順 4、 3の画像 2 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 手順 4、 3の画像 3
    • Flip the laptop over and open it up so the screen is facing up and the top of the screen is facing you.
    • Use a plastic opening tool to separate the the touchscreen from the back cover.
    • Carefully work your way around the frame and gently pry. Be careful not to brake the frame or damage the screen.
  5. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 手順 5、 3の画像 1 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 手順 5、 3の画像 2 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 手順 5、 3の画像 3
    • Disconnect the display cable by first taking off the tape using a metal spudger and then pulling on the black tab.
  6. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 手順 6、 2の画像 1 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 手順 6、 2の画像 2
    • Take off the yellow tape connecting the display to the border.
  7. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 手順 7、 2の画像 1 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 手順 7、 2の画像 2
    • Pull back the adhesive using the metal spudger.
    • Pry out the camera by lifting the adhesive with the metal spudger. Then, remove the camera by lifting it up by one side.
  8. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 手順 8、 1の画像 1
    • Remove the two brackets holding the displays by unscrewing both M1 .6x3 screws with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 手順 9、 1の画像 1
    • Release the display from the border using your hands.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Caleb lindsay
メンバー登録日: 04/11/16
778 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 34-15, Maness Spring 2016 Cal Poly, Team 34-15, Maness Spring 2016人のメンバー
CPSU-MANESS-S16S34G15
4 メンバー
6のガイドは作成済み
コメント 1 件
the touchscreen its glue together with the LCD?
Chris Foliaki - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 5
今までの合計 1,190
