メインコンテンツにスキップ
Acer Aspire E1-510P-4637 CMOS Battery Replacement
必要な工具と部品
  1. Acer Aspire E1-510P-4637 CMOS Battery Replacement, Battery: 手順 1、 1の画像 1
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 CMOS Battery Replacement: 手順 2、 1の画像 1
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 CMOS Battery Replacement, Hard Drive: 手順 3、 1の画像 1
    • Remove the M2.5x8 screw with a PH1 screwdriver.
  4. Acer Aspire E1-510P-4637 CMOS Battery Replacement: 手順 4、 1の画像 1
    • Use the plastic opening tool to pop off the small back cover.
  5. Acer Aspire E1-510P-4637 CMOS Battery Replacement: 手順 5、 1の画像 1
    • Use a PH0 Phillips screwdriver to remove the screw securing the hard drive.
  6. Acer Aspire E1-510P-4637 CMOS Battery Replacement: 手順 6、 2の画像 1 Acer Aspire E1-510P-4637 CMOS Battery Replacement: 手順 6、 2の画像 2
    • Use a nylon spudger to slightly pry up the hard drive near the screw holes.
  7. Acer Aspire E1-510P-4637 CMOS Battery Replacement: 手順 7、 3の画像 1 Acer Aspire E1-510P-4637 CMOS Battery Replacement: 手順 7、 3の画像 2 Acer Aspire E1-510P-4637 CMOS Battery Replacement: 手順 7、 3の画像 3
    • Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
    • The hard drive connector is fragile. Handle with care.
  8. Acer Aspire E1-510P-4637 CMOS Battery Replacement, CMOS Battery: 手順 8、 1の画像 1
    • Remove the fourteen M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 CMOS Battery Replacement: 手順 9、 1の画像 1
    • Slide out the disk drive tray.
  10. Acer Aspire E1-510P-4637 CMOS Battery Replacement: 手順 10、 1の画像 1
    • Use the plastic opening tool to gently pry open the laptop.
  11. Acer Aspire E1-510P-4637 CMOS Battery Replacement: 手順 11、 1の画像 1
    • Slowly rotate the back cover up to reveal cables attached to the motherboard.
    • Carefully slide the connectors out of their receptacle to remove the back panel.
    • The connectors are very small and fragile. Handle with care.
  12. Acer Aspire E1-510P-4637 CMOS Battery Replacement: 手順 12、 2の画像 1 Acer Aspire E1-510P-4637 CMOS Battery Replacement: 手順 12、 2の画像 2
    • Open the up the laptop to reveal the CMOS battery.
    • Desolder the CMOS battery to remove it. For soldering help, check out iFixit's soldering guide.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Caleb lindsay
メンバー登録日: 04/11/16
778 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 34-15, Maness Spring 2016 Cal Poly, Team 34-15, Maness Spring 2016人のメンバー
CPSU-MANESS-S16S34G15
4 メンバー
6のガイドは作成済み
2 件のコメント
molto utile e ben fatta, anche se il mio problema è più legato alla alimentazione che pare non funzionare anche senza batteria
Franco Ferrandi - 返信
It'd be really handy if you were to list the model number of the CMOS battery so we can order one in advance.
Dave Compton (SirCompo) - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 35
今までの合計 17,228
