はじめに
The fan helps circulate air through a laptop and cool off important pieces. A broken or dirty fan can cause overheating.
必要な工具と部品
Using a Phillips 1 screwdriver, remove the 17 9 mm screws from the bottom of the laptop, including the one in the back panel.
Using a plastic opening tool, carefully remove the back panel.
Remove the 9mm screw under the back panel.
この手順で使用する道具:Tweezers$4.99
Open the laptop, leaving the screen flat on the table.
Carefully pull the keyboard assembly out away from the base of the laptop. There should be three connections visible in the gap between the keyboard assembly and the base.
Using tweezers, carefully detach the connections from the base.
Place the keyboard assembly and the disk tray place holder aside.
