はじめに
This guide will walk you through the process of replacing the Touchpad on an Acer Aspire E 11.
必要な工具と部品
Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
Press and hold the small black button located on the motherboard just above the battery for five seconds.
Carefully remove the battery by lifting it out of the casing.
Locate the keyboard cable on the motherboard. Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard.
2 の人々がこのガイドを完成させました。
コメント 1 件
Some of the bullet points can be broken up into information points or divided into more bullet points per step. Also, make sure that the exposure is high enough so that some of the images are brighter and visible.
