はじめに
This guide will walk you through the process of replacing the RAM on an Acer Aspire E 11.
ツール
パーツ
パーツは指定されていません。
Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
Press and hold the small black button located on the motherboard just above the battery for five seconds.
Locate the keyboard cable on the motherboard. Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard.
2 の人々がこのガイドを完成させました。
