メインコンテンツにスキップ
Acer Aspire E 11 Motherboard Replacement
必要な工具と部品
  1. Acer Aspire E 11 Motherboard Replacement, Lower Case: 手順 1、 2の画像 1 Acer Aspire E 11 Motherboard Replacement, Lower Case: 手順 1、 2の画像 2
    • Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
  2. Acer Aspire E 11 Motherboard Replacement: 手順 2、 3の画像 1 Acer Aspire E 11 Motherboard Replacement: 手順 2、 3の画像 2 Acer Aspire E 11 Motherboard Replacement: 手順 2、 3の画像 3
    • Lift the back panel using a plastic opening tool. Slowly make your way around the device until the back panel comes off.
  3. Acer Aspire E 11 Motherboard Replacement, Battery: 手順 3、 2の画像 1 Acer Aspire E 11 Motherboard Replacement, Battery: 手順 3、 2の画像 2
    • Press and hold the small black button located on the motherboard just above the battery for five seconds.
    Whats this button for actually? What does it do?
    Wadi Wahab - 返信
  4. Acer Aspire E 11 Motherboard Replacement: 手順 4、 3の画像 1 Acer Aspire E 11 Motherboard Replacement: 手順 4、 3の画像 2 Acer Aspire E 11 Motherboard Replacement: 手順 4、 3の画像 3
    • Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug.
  5. Acer Aspire E 11 Motherboard Replacement: 手順 5、 3の画像 1 Acer Aspire E 11 Motherboard Replacement: 手順 5、 3の画像 2 Acer Aspire E 11 Motherboard Replacement: 手順 5、 3の画像 3
    • Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery.
  6. Acer Aspire E 11 Motherboard Replacement: 手順 6、 1の画像 1
    • Carefully remove the battery by lifting it out of the casing.
    The E-11 that I have has 2 screws on each end of the battery. 1 at the upper left corner, 1 at the lower left corner, 1 at upper right corner and 1 approx 1" below upper right and inboard approx 1/2". Battery #AC13C34 (3ICP5/60/80).
    [deleted] - 返信
  7. Acer Aspire E 11 Motherboard Replacement, Motherboard: 手順 7、 3の画像 1 Acer Aspire E 11 Motherboard Replacement, Motherboard: 手順 7、 3の画像 2 Acer Aspire E 11 Motherboard Replacement, Motherboard: 手順 7、 3の画像 3
    • Locate the keyboard cable on the motherboard. Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard.
  8. Acer Aspire E 11 Motherboard Replacement: 手順 8、 3の画像 1 Acer Aspire E 11 Motherboard Replacement: 手順 8、 3の画像 2 Acer Aspire E 11 Motherboard Replacement: 手順 8、 3の画像 3
    • Use a plastic opening tool to carefully lift the white hinge up on the touchpad cable connector, and gently remove the cable from the motherboard.
  9. Acer Aspire E 11 Motherboard Replacement: 手順 9、 3の画像 1 Acer Aspire E 11 Motherboard Replacement: 手順 9、 3の画像 2 Acer Aspire E 11 Motherboard Replacement: 手順 9、 3の画像 3
    • Use two plastic opening tools to grip each side of the connector for the speaker cable and gently pull the cable from the motherboard.
  10. Acer Aspire E 11 Motherboard Replacement: 手順 10、 3の画像 1 Acer Aspire E 11 Motherboard Replacement: 手順 10、 3の画像 2 Acer Aspire E 11 Motherboard Replacement: 手順 10、 3の画像 3
    • Remove the tape on the connector for the display cable.
    • Use two plastic opening tools to grip each side of the connector and gently pull the display cable from the motherboard.
  11. Acer Aspire E 11 Motherboard Replacement: 手順 11、 2の画像 1 Acer Aspire E 11 Motherboard Replacement: 手順 11、 2の画像 2
    • Remove one 6.2 mm Phillips #1 screw from the wireless chip on the left side of the motherboard.
  12. Acer Aspire E 11 Motherboard Replacement: 手順 12、 3の画像 1 Acer Aspire E 11 Motherboard Replacement: 手順 12、 3の画像 2 Acer Aspire E 11 Motherboard Replacement: 手順 12、 3の画像 3
    • Remove three 6.2 mm Phillips #1 screws that attach the motherboard to the laptop casing.
  13. Acer Aspire E 11 Motherboard Replacement: 手順 13、 1の画像 1
    • Return to the wireless chip and gently pull it from the connector on the side of the motherboard.
  14. Acer Aspire E 11 Motherboard Replacement: 手順 14、 1の画像 1
    • The motherboard can now be lifted out from the laptop casing.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Carlos Rodriguez
メンバー登録日: 02/04/16
420 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 16-1, Blackwell Winter 2016 USF Tampa, Team 16-1, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S16G1
4 メンバー
11のガイドは作成済み
3 件のコメント
Some of the bullet points can be broken up into information points or divided into more bullet points per step. Also, make sure the exposure is high enough to make all parts visible
Jaie Hillery - 返信
Hello, What is WiFi+BT card model ? Is it Atheros?
Da K - 返信
Me podrían decir cual es el modelo de la pila del BIOS de este modelo e11 , por favor
Jesus Quiroz - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 24
今までの合計 5,287
