メインコンテンツにスキップ
Acer Aspire 7736Z-4809 Keyboard Replacement
必要な工具と部品
  1. Acer Aspire 7736Z-4809 Keyboard Replacement, Acer Aspire 7736Z-4809 Repair Preparation: 手順 1、 1の画像 1
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 2、 1の画像 1
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 Keyboard Replacement, Keyboard: 手順 3、 2の画像 1 Acer Aspire 7736Z-4809 Keyboard Replacement, Keyboard: 手順 3、 2の画像 2
    • Use the Phillips #1 screwdriver to remove the three 4.5mm Phillips #1 screws.
  4. Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 4、 3の画像 1 Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 4、 3の画像 2 Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 4、 3の画像 3
    • Orient the laptop so that the hinges between the LCD module and the laptop's bottom base are visible.
    • Use the plastic opening tools to separate the speaker panel from the laptop.
  5. Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 5、 2の画像 1 Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 5、 2の画像 2
    • Flip over the LCD module of the laptop.
    • Insert the opening tool into the crack between the panel and the frame at either end. Slide the opening tool across the line. Reinsert the opening tool into the crack and apply leverage until the frame releases.
    • Repeat this step with the other side of the laptop.
  6. Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 6、 3の画像 1 Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 6、 3の画像 2 Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 6、 3の画像 3
    • Gently hold the speaker panel by the sides and pull upwards to release the panel.
  7. Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 7、 1の画像 1
    • Use the flat end of the medium sized metal spudger tool to release the two tabs at the top of the keyboard.
    • Do not remove the keyboard yet.
  8. Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 8、 3の画像 1 Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 8、 3の画像 2 Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 8、 3の画像 3
    • Insert a finger into the opening above the F11 key and pry the keyboard until it is released from the casing.
  9. Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 9、 3の画像 1 Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 9、 3の画像 2 Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 9、 3の画像 3
    • Gently raise the keyboard with your hands.
  10. Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 10、 3の画像 1 Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 10、 3の画像 2 Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 10、 3の画像 3
    • Lift the black latch upwards to release the ZIF connector.
  11. Acer Aspire 7736Z-4809 Keyboard Replacement: 手順 11、 1の画像 1
    • Remove the keyboard from the keyboard slot.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Pnithan Jantarakolica
メンバー登録日: 09/22/16
1,153 ポイント
10のガイドは作成済み
チーム
UC Davis, Team 2-4, Oliver Fall 2016 UC Davis, Team 2-4, Oliver Fall 2016人のメンバー
UCD-OLIVER-F16S2G4
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 1,178
