メインコンテンツにスキップ
Acer Aspire 7736Z-4809 CPU Fan Replacement
必要な工具と部品
  1. Acer Aspire 7736Z-4809 CPU Fan Replacement, Acer Aspire 7736Z-4809 Repair Preparation: 手順 1、 1の画像 1
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 CPU Fan Replacement: 手順 2、 1の画像 1
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: 手順 3、 2の画像 1 Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: 手順 3、 2の画像 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 CPU Fan Replacement: 手順 4、 3の画像 1 Acer Aspire 7736Z-4809 CPU Fan Replacement: 手順 4、 3の画像 2 Acer Aspire 7736Z-4809 CPU Fan Replacement: 手順 4、 3の画像 3
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 CPU Fan Replacement: 手順 5、 1の画像 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: 手順 6、 3の画像 1 Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: 手順 6、 3の画像 2 Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: 手順 6、 3の画像 3
    • Use tweezers to remove the fan cable from its slot.
    • The cables consist of red, black, and yellow wires.
  7. Acer Aspire 7736Z-4809 CPU Fan Replacement: 手順 7、 2の画像 1 Acer Aspire 7736Z-4809 CPU Fan Replacement: 手順 7、 2の画像 2
    • Use the Phillips #1 screwdriver to unscrew the four Phillips #1 screws that connect the cooling fan from the panel.
    • These screws are held in the unit via springs. You cannot remove them. They can only be loosened.
  8. Acer Aspire 7736Z-4809 CPU Fan Replacement: 手順 8、 3の画像 1 Acer Aspire 7736Z-4809 CPU Fan Replacement: 手順 8、 3の画像 2 Acer Aspire 7736Z-4809 CPU Fan Replacement: 手順 8、 3の画像 3
    • Carefully remove the cooling fan from the motherboard.
    • Slightly lift up the fan, gradually slide it towards you and then fully remove it from the case.
  9. Acer Aspire 7736Z-4809 CPU Fan Replacement: 手順 9、 1の画像 1
    • Install the modified or new cooling fan.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Pnithan Jantarakolica
メンバー登録日: 09/22/16
1,153 ポイント
10のガイドは作成済み
チーム
UC Davis, Team 2-4, Oliver Fall 2016 UC Davis, Team 2-4, Oliver Fall 2016人のメンバー
UCD-OLIVER-F16S2G4
5 メンバー
10のガイドは作成済み
コメント 1 件
You’ll need some thermal compound when reinstalling for the heat syncs under the copper tube.
Minks - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 784
