メインコンテンツにスキップ
Acer Aspire 6530-6522 Secondary Hard Drive Replacement
必要な工具と部品
  1. Acer Aspire 6530-6522 Secondary Hard Drive Replacement, Battery: 手順 1、 2の画像 1 Acer Aspire 6530-6522 Secondary Hard Drive Replacement, Battery: 手順 1、 2の画像 2
    • Make sure the device is unplugged and completely powered down.
    • Turn the device over.
  2. Acer Aspire 6530-6522 Secondary Hard Drive Replacement: 手順 2、 2の画像 1 Acer Aspire 6530-6522 Secondary Hard Drive Replacement: 手順 2、 2の画像 2
    • The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
    • Slide the switch away from the battery.
  3. Acer Aspire 6530-6522 Secondary Hard Drive Replacement: 手順 3、 3の画像 1 Acer Aspire 6530-6522 Secondary Hard Drive Replacement: 手順 3、 3の画像 2 Acer Aspire 6530-6522 Secondary Hard Drive Replacement: 手順 3、 3の画像 3
    • The battery release switch is just to the inside of the battery and slides parallel to it.
    • Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
    • When inserting a battery back into the device, you do not need to touch this switch. Just press the battery firmly down, you will see and hear this switch catch.
  4. Acer Aspire 6530-6522 Secondary Hard Drive Replacement: 手順 4、 3の画像 1 Acer Aspire 6530-6522 Secondary Hard Drive Replacement: 手順 4、 3の画像 2 Acer Aspire 6530-6522 Secondary Hard Drive Replacement: 手順 4、 3の画像 3
    • Pull the battery up and out. Use a plastic opening tool if necessary.
  5. Acer Aspire 6530-6522 Secondary Hard Drive Replacement, Secondary Hard Drive: 手順 5、 2の画像 1 Acer Aspire 6530-6522 Secondary Hard Drive Replacement, Secondary Hard Drive: 手順 5、 2の画像 2
    • While looking at the bottom of the device upside down from the front, the secondary hard drive is in the near, left corner.
    • Using a Phillips #1 screwdriver, remove the two 7mm screws on the right side of the cover.
  6. Acer Aspire 6530-6522 Secondary Hard Drive Replacement: 手順 6、 1の画像 1
    • Using a Phillips #1 screwdriver, remove the two 3mm screws near the front of the device.
    • Using the plastic pull tab to pull the drive to the left, away from the connections.
    • Lift the drive up and out of the device.
  7. Acer Aspire 6530-6522 Secondary Hard Drive Replacement: 手順 7、 3の画像 1 Acer Aspire 6530-6522 Secondary Hard Drive Replacement: 手順 7、 3の画像 2 Acer Aspire 6530-6522 Secondary Hard Drive Replacement: 手順 7、 3の画像 3
    • Using the Phillips #1 screwdriver, remove the four 3.5mm screws at the corners of the cover.
    • Lift the cover off the hard drive.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
William Michaud
メンバー登録日: 03/20/18
343 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G6, Peak Spring 2018 UMass Dartmouth, Team S5-G6, Peak Spring 2018人のメンバー
UMASSD-PEAK-S18S5G6
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 244
