はじめに
This guide will how you how to remove the power board under the power button on your Acer Aspire 6530-6522. You will need to do this if it becomes faulty or gets damaged.
必要な工具と部品
Using the Phillips #1 screwdriver, remove the ten 7mm screws in the bottom of the device that are holding the top panel.
Turn the device over and open it.
もう少しです!
終わりに
