メインコンテンツにスキップ
Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement
必要な工具と部品
  1. Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement, Battery: 手順 1、 2の画像 1 Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement, Battery: 手順 1、 2の画像 2
    • Make sure the device is unplugged and completely powered down.
    • Turn the device over.
  2. Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement: 手順 2、 2の画像 1 Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement: 手順 2、 2の画像 2
    • The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
    • Slide the switch away from the battery.
  3. Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement: 手順 3、 3の画像 1 Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement: 手順 3、 3の画像 2 Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement: 手順 3、 3の画像 3
    • The battery release switch is just to the inside of the battery and slides parallel to it.
    • Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
    • When inserting a battery back into the device, you do not need to touch this switch. Just press the battery firmly down, you will see and hear this switch catch.
  4. Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement: 手順 4、 3の画像 1 Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement: 手順 4、 3の画像 2 Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement: 手順 4、 3の画像 3
    • Pull the battery up and out. Use a plastic opening tool if necessary.
  5. Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement, Optical Disk Drive (CD/DVD): 手順 5、 2の画像 1 Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement, Optical Disk Drive (CD/DVD): 手順 5、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the 7mm screw holding the drive.
  6. Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement: 手順 6、 2の画像 1 Acer Aspire 6530-6522 Optical Disk Drive (CD/DVD) Replacement: 手順 6、 2の画像 2
    • Slide the drive out of the bay.
終わりに
作成者
1人の作成者と共同作成されました。
Patrick McKenna
メンバー登録日: 03/20/18
656 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G6, Peak Spring 2018 UMass Dartmouth, Team S5-G6, Peak Spring 2018人のメンバー
UMASSD-PEAK-S18S5G6
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 166
