はじめに
This guide will show you how to remove the hard drive. You will need to do this if your hard drive is damaged or faulty and you have a new one, or if you are upgrading to larger one.
必要な工具と部品
Using the Phillips #1 screwdriver remove the nine 7mm screws in the bottom panel.
Lift and remove the panel.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
