メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
The optical drive is where CDs and DVDs are inserted and read in a laptop. Optical drives have various moving parts so they can malfunction or stop working properly. The optical drive can be removed easily in order to replace it.
パーツ
パーツは指定されていません。
  1. Unplug the charging cable from the laptop and the wall. Failure to disconnect the charging cable could result in electric shock. Turn the laptop over.
    • Unplug the charging cable from the laptop and the wall. Failure to disconnect the charging cable could result in electric shock.
    • Turn the laptop over.
    • Locate the orange switch next to the battery.
  2. Using  a small tool such as tweezers or a pen,  slide the orange  switch completely to the left to unlock  the battery. While holding the orange switch in place, lift the battery by the lip and pull it away from the laptop. While holding the orange switch in place, lift the battery by the lip and pull it away from the laptop.
    • Using a small tool such as tweezers or a pen, slide the orange switch completely to the left to unlock the battery.
    • While holding the orange switch in place, lift the battery by the lip and pull it away from the laptop.
  3. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  4. Locate the black screw just above the battery. Remove the black screw holding the optical drive in place by using a Phillips #0 screwdriver.
    • Locate the black screw just above the battery.
    • Remove the black screw holding the optical drive in place by using a Phillips #0 screwdriver.
  5. Pull the optical drive free from the laptop. Pull the optical drive free from the laptop.
    • Pull the optical drive free from the laptop.
終わりに
Chelsea Taylor
メンバー登録日: 2017年01月18日
355 ポイント
3のガイドは作成済み
チーム
Eastern Washington University, Team 2-5, Crane Winter 2017 Eastern Washington University, Team 2-5, Crane Winter 2017人のメンバー
EWU-CRANE-W17S2G5
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 686
