メインコンテンツにスキップ
Acer Aspire 5750-6667 Memory Replacement
必要な工具と部品
  1. Acer Aspire 5750-6667 Memory Replacement, Battery: 手順 1、 2の画像 1 Acer Aspire 5750-6667 Memory Replacement, Battery: 手順 1、 2の画像 2
    • Unplug the charging cable from the laptop and the wall. Failure to disconnect the charging cable could result in electric shock.
    • Turn the laptop over.
    • Locate the orange switch next to the battery.
  2. Acer Aspire 5750-6667 Memory Replacement: 手順 2、 3の画像 1 Acer Aspire 5750-6667 Memory Replacement: 手順 2、 3の画像 2 Acer Aspire 5750-6667 Memory Replacement: 手順 2、 3の画像 3
    • Using a small tool such as tweezers or a pen, slide the orange switch completely to the left to unlock the battery.
    • While holding the orange switch in place, lift the battery by the lip and pull it away from the laptop.
  3. Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: 手順 3、 3の画像 1 Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: 手順 3、 3の画像 2 Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: 手順 3、 3の画像 3
    • Flip the laptop over and locate the bottom access panel. It is opposite the battery.
    • Locate the 2 screws that hold the panel in place and unscrew them using a Phillips PH0 screwdriver.
  4. Acer Aspire 5750-6667 Memory Replacement: 手順 4、 3の画像 1 Acer Aspire 5750-6667 Memory Replacement: 手順 4、 3の画像 2 Acer Aspire 5750-6667 Memory Replacement: 手順 4、 3の画像 3
    • Use the blue plastic opening tool to lift the panel away from the laptop.
  5. Acer Aspire 5750-6667 Memory Replacement, RAM: 手順 5、 3の画像 1 Acer Aspire 5750-6667 Memory Replacement, RAM: 手順 5、 3の画像 2 Acer Aspire 5750-6667 Memory Replacement, RAM: 手順 5、 3の画像 3
    • Lift the clear plastic flap and locate the pair of metal brackets that are holding the top RAM in place.
    • Using your thumbs, push the brackets away from the RAM . It should pop up when released.
    • You can now gently pull the top RAM out of the laptop.
  6. Acer Aspire 5750-6667 Memory Replacement: 手順 6、 3の画像 1 Acer Aspire 5750-6667 Memory Replacement: 手順 6、 3の画像 2 Acer Aspire 5750-6667 Memory Replacement: 手順 6、 3の画像 3
    • Locate the second pair of metal clasps holding the bottom RAM in place.
    • Using your thumbs, push the brackets away from the RAM . The RAM board should pop up when released.
    • You can now gently pull the top RAM out of the laptop. Repeat for any other RAM boards that may be in the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Chelsea Taylor
メンバー登録日: 01/18/17
380 ポイント
3のガイドは作成済み
チーム
Eastern Washington University, Team 2-5, Crane Winter 2017 Eastern Washington University, Team 2-5, Crane Winter 2017人のメンバー
EWU-CRANE-W17S2G5
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 8
今までの合計 851
