はじめに
The bottom access panel can be easily removed in order to gain access to components of the laptop including the memory cards, wireless card and dial up modem. This panel requires the user to remove two screws in order to gain access to the panel.
必要な工具と部品
Flip the laptop over and locate the bottom access panel. It is opposite the battery.
Locate the 2 screws that hold the panel in place and unscrew them using a Phillips PH0 screwdriver.
ある他の人がこのガイドを完成しました。
