メインコンテンツにスキップ
Acer Aspire 5749 Fan/HeatSink Replacement
必要な工具と部品
  1. Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: 手順 1、 3の画像 1 Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: 手順 1、 3の画像 2 Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: 手順 1、 3の画像 3
    • Retrieve all Screw's from the bottom of the laptop and organize them into 2 different sets.
    • When removing the back cover gently press on audio connections on the back right of the laptop.
    Performed on a 5479-6413, several screws that needed to be removed are not indicated in this picture - suffice it to say "remove all visible screws." The hint about the audio jacks was useful, but they are on the bottom right of the photo, the front of the machine not the back.
    kurt - 返信
  2. Acer Aspire 5749 Fan/HeatSink Replacement: 手順 2、 3の画像 1 Acer Aspire 5749 Fan/HeatSink Replacement: 手順 2、 3の画像 2 Acer Aspire 5749 Fan/HeatSink Replacement: 手順 2、 3の画像 3
    • Carefully release and unplug every wire that connects to the fan.
  3. Acer Aspire 5749 Fan/HeatSink Replacement: 手順 3、 3の画像 1 Acer Aspire 5749 Fan/HeatSink Replacement: 手順 3、 3の画像 2 Acer Aspire 5749 Fan/HeatSink Replacement: 手順 3、 3の画像 3
    • Release the screw that connects the fan to the base of the laptop. Carefully remove your fan and heat sink.
    • Apply heat paste to the center before replacing the fan and heat sink. Then reinsert the screw and plugs.
終わりに
8 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
JeanChristophe
メンバー登録日: 11/19/10
523 ポイント
3のガイドは作成済み
5 件のコメント
May need to expand the "apply heat paste to center" section. Need to remove old paste first, etc. etc. A good bird's eye view intro, though
polishtext4 - 返信
Tanks you…
I'll look forward for adding this info.
JeanChristophe -
Seemed like I was going to rip the motherboard up where the usb ports are by the audio connector, why isn't the %#*@ thing screwed down? Lol If I push down by the audio connector like you mention and pull it up from the other side will ot be fine, felt and looked like I might snap the board.
Clayton Boyle - 返信
Good job, did have to Emphasis about releasing the audio connectors
Thaine Ferris - 返信
I didn't know how to explain better…
Some trick of trade?
JeanChristophe -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 23
今までの合計 7,626
