必要な工具と部品
Use spudger to gently pry off open middle cover.
Then flip the middle cover over onto the keyboard.
手順7 Prepare Acer Aspire 5740-5780 for Disassembly
注意: 手順 7-10 は、作業進行中としてマークされている ガイド から引用されています。
Turn the laptop off and remove the power cord.
Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
