はじめに
This guide is short photo-tutorial on how to swap the keyboard and top case of Acer Aspire 5542g
必要な工具と部品
Remove all screws on the bottom of laptop. Remove HD cover (it's not necessary to remove battery and RAM cover)
3 の人々がこのガイドを完成させました。
3 件のコメント
Hi,
if you have old keyboard at least partially working, try to put it back. If it works. probably the problem is with the new keyboard.
If the old one also doesn't work, the problem is probably with motherboard connector or software (less probable). To check the software problem, i think it's possible to load the laptop from any linux live cd or some other OS different from what s installed on your pc.
Please be aware i'm not professional pc service man and these are just common thoughts (hope helpful)
Battery death solution please
