はじめに
The motherboard is the part that connects all of a computer's components together and allows them to talk to each other. This guide demonstrates step by step how to replace the motherboard in an Acer Aspire 5336-2524 laptop. Changing your motherboard should be a last resort, especially if you have a newer computer. However, if your computer keeps crashing, or consistently keeps having errors, you might find this guide helpful. Some other reasons to replace the motherboard include: improvements to your graphics, faster RAM, and improved storage space. Before replacing the motherboard be sure to set aside a good amount of time to complete the project.
必要な工具と部品
特集記事
Flip over the laptop.
Make sure the battery lock is pushed down so the red part is exposed.
Push the switch all the way to the side and that will push the battery up.
Remove the battery.
Flip over the laptop and remove all eleven of the M2.5x8 screws on the bottom of the laptop with a Phillips #0 screwdriver.
Remove all four of the M2x3 screws with a Phillips #0 screwdriver.
Open the laptop.
Wedge the spudger or iFixit opening tool between the side of the keyboard and the laptop and apply a slight amount of upward pressure.
Push in the latches at the top of the keyboard using the spudger to release that part of the keyboard, and start to lift up the keyboard more and more as you push in the latches.
Remove the ribbon cable that connects the keyboard to the motherboard by pushing the black latch downward and then pulling the cable out.
ある他の人がこのガイドを完成しました。
