必要な工具と部品
After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
Hello. Vous avez oublié de mentionner le démontage du disque dur (une vis) et le débranchement des fils des antennes wifi qui ne gênent pas pour vous lors du démontage de la carte mère.
Locate the tabs keeping the keyboard in place.
Using thin tweezers push the tabs in the keyboard in and pull up on the edge of the keyboard.
I’m attempting this but my keyboard doesn’t move and I can’t get it to pop up so I can remove it.
After you have removed all of the prerequisites its time to unscrew a few more screws. Flip your laptop over and first remove all the screw highlighted in red with the Phillips #00 screwdriver. These are 1/4" head diameter by 3/8" screw length screws.
Now remove the screws highlighted in orange with the Phillips #00 screwdriver. These are 5/32" head diameter by 5/32" screw length screws. Keep these separate from the other screws.
Hello. Il manque un rond rouge autour de la vis qu’on aperçoit sur la gauche, à peu près au milieu de la longueur des barettes mémoire. Celle-ci et celle du disque dur (oublié plus haut) bloquent le retrait du couvercle supérieur.
Flip the Laptop back over, and unscrew the 1/4" diameter head 7/32" length screws indicated in the picture.
Il manque un rond rouge sur la vis à droite du connecteur écran, bien qu’on voie qu’elle est enlevée sur la seconde image.
Here is a close-up of all of the connectors. Remember to use tweezers on the black part and carefully pull out both sides. Once it has been moved back slightly, pull the connector out just like the keyboard.
The third picture shows the connector to the speakers which can just be pulled straight out by tweezers.
Now locate the three 1/4" diameter head and 7/32" length screws shown in the picture, and remove them with a #00 Phillips screwdriver.
Lift the motherboard carefully, and locate the last wire bundle that needs to be removed.
Confirmant mes précédentes remarques : on voit bien que le disque dur n’est plus présent et que la carte wifi a été démontée. Il faudrait en parler car au remontage on peut se demander comment rebrancher les antennes (fills noir et blanc) si on n’a pas noté comment ils étaient avant de les retirer… J’ai trouvé une info ailleurs : Fil noir sur le “main” ou connecteur 1, alias “main in balck” ;-)
The motherboard should now be completely free of connections and easily removed.
J’espère que mes remarques vous permettront d’apporter quelques précisions. Félicitations pour cette présentation qui est claire et excellente, j’ai pu parvenir à démonter (ET remonter !) le pc sans (trop) de problèmes. Je préfère grandement ces tutoriels en photos et commentaires plutôt que des vidéos plus ou moins bien faites. Bravo aux auteurs de ce tuto et bonne continuation. Excellent travail.
17 の人々がこのガイドを完成させました。
2 件のコメント
The removal of the hard drive and wireless antenna wires where not included as a step, this had caused problems for a friend performing this repair. Both the hard drive and the antenna wires should be disconnected around step 9 and 10, as they are needed for motherboard removal and the point in the instructions puts them in the same area being worked on.
Once the motherboard is removed do you replace it with a new one or just put everything back?
