メインコンテンツにスキップ
Acer Aspire 5253 Battery Replacement
  1. Acer Aspire 5253 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop over.
  2. Acer Aspire 5253 Battery Replacement: 手順 2、 1の画像 1
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
  3. Acer Aspire 5253 Battery Replacement: 手順 3、 1の画像 1
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
  4. Acer Aspire 5253 Battery Replacement: 手順 4、 1の画像 1
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
  5. Acer Aspire 5253 Battery Replacement: 手順 5、 1の画像 1
    • You have successfully removed the battery. Congratulations!
終わりに
To reassemble your device, return battery pack to designated area. Push down until you hear a click, then lock the battery back into place.
7 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Joseph Gagliano
メンバー登録日: 04/08/14
573 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 8-11, Regan Spring 2014 Cal Poly, Team 8-11, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S8G11
4 メンバー
15のガイドは作成済み
3 件のコメント
I have just bought aa new battery but wont hold the charge
Paul MGreor - 返信
Just bought a new battery and still draining faat
Paul MGreor - 返信
My computer acer aspire 21-531 has a blank screen with a blue two line enter current password when I try to enter the password it does not take it we had reset my computer and got this. Please help
Melinda harbison - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 17
今までの合計 11,926
