この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Replace the track pad for an Acer Aspire 5100.
必要な工具と部品
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
On the back of the laptop, locate and unscrew all nine of the screws located at the edges.
2 の人々がこのガイドを完成させました。
3 件のコメント
You left out about 10 screws & assemblies that have to ALSO be removed to release the cover that surrounds the keyboard and track pad.
You have to remove the video cable, wifi cables and LCD before you try to remove the touchpad/upper cover. You must also remove two screws from the bottom labeled 10x. In other words, you should remove the parts I mentioned before attempting to complete steps 5 to 7.
The Fan must also be removed before removing the touchpad/upper cover.
