はじめに
If your Acer Aspire 5100 track pad is not always clicking or not clicking at all, use this guide to replace the track pad.
The trackpad of this device allows the user to move the cursor using their fingers and use the clicking function to select wanted features on the screen. A faulty trackpad can cause the Acer Aspire 5100 to have a jittery cursor, loss of cursor control, or loss of the clicking function on the trackpad.
Before replacing the trackpad, inspect the trackpad connection as well as any debris that might be in the surrounding areas. Occasionally dust can build up and cause connection issues in the track pad.
Once the surrounded areas have been inspected, use this guide to replace the track pad on your Acer Aspire 5100. Be sure the the device is powered down and unplugged from any external power sources.
必要な工具と部品
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
Under the panel, remove the two screws that connect the keyboard to the laptop.
Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
Pull the ribbon under the keyboard to detach it from the motherboard.
Remove the keyboard.
do not pull on ribbon it will only break the cable. instead use tool to detach from mother board. i broke mine by pulling ribbon.
steve foss - 返信
useless guide, there are a lot of screws that lock the cover on the laptop and you have never showed them
You do not need to remove the whole cover, in order to replace the keyboard.
The description for this job is right.
The switch plate cover just pops off.
Screws revealed, secure the keyboard.
Unclip the ribbon cable.
Job done
Richard -
Remove the nine screws from the back edges of the laptop.
2 の人々がこのガイドを完成させました。
3 件のコメント
You left out about 10 screws & assemblies that have to ALSO be removed to release the cover that surrounds the keyboard and track pad.
You have to remove the video cable, wifi cables and LCD before you try to remove the touchpad/upper cover. You must also remove two screws from the bottom labeled 10x. In other words, you should remove the parts I mentioned before attempting to complete steps 5 to 7.
The Fan must also be removed before removing the touchpad/upper cover.
