はじめに
This guide will show you how to replace the motherboard in an Acer Aspire 5100 laptop. This is needed when your laptop begins to shut down or freeze. A motherboard can also be referred to as a mainboard. A motherboard is an essential part of a computer system. This can be used if you need to change the hardware or clean it. This task can serve to help you complete any repairs or upgrades you want to make. Be aware this replacement requires a lot of delicate work.
必要な工具と部品
Open and push the screen back all the way until it is horizontal with the rest of the laptop.
Use an opening tool to remove the panel above the keyboard that has the power button on it.
After you have released the tabs, lift up the panel.
Under the panel, remove the two screws that connect the keyboard to the laptop.
Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
Pull the ribbon under the keyboard to detach it from the motherboard.
Remove the keyboard.
do not pull on ribbon it will only break the cable. instead use tool to detach from mother board. i broke mine by pulling ribbon.
steve foss - 返信
useless guide, there are a lot of screws that lock the cover on the laptop and you have never showed them
You do not need to remove the whole cover, in order to replace the keyboard.
The description for this job is right.
The switch plate cover just pops off.
Screws revealed, secure the keyboard.
Unclip the ribbon cable.
Job done
Richard -
Remove the nine screws from the back edges of the laptop.
8 の人々がこのガイドを完成させました。
6 件のコメント
Thank you. I followed the guide as closely as possible. I am installing Windows 76 Ultimate on it again.
Thank you!
a lot of stuff missing in terms of unscrewing certain screws to get the cover off. I got stuck at step 10 because the cover was still attached by various screws.
Maybe I have a different model, but it is for sure an Acer Aspire 5100.
I also broke a lot of connection where screws thread in to, hopefully it goes back together rigidly enough.
You have to remove the video cable, wifi cables and LCD before you try to remove the touchpad/upper cover. You must also remove two screws from the bottom labeled 10x. In other words, you should complete steps 12 to 16 and remove the 10x screws before attempting to complete steps 9 to 11.
The Fan must also be removed before removing the touchpad/upper cover.
4screws 10mm
dhsttite@hotmail.com - 返信
4 screws 10mm.
