メインコンテンツにスキップ
Acer Aspire 5100 LCD Monitor Replacement
必要な工具と部品
  1. Acer Aspire 5100 LCD Monitor Replacement, Keyboard: 手順 1、 2の画像 1 Acer Aspire 5100 LCD Monitor Replacement, Keyboard: 手順 1、 2の画像 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 LCD Monitor Replacement: 手順 2、 3の画像 1 Acer Aspire 5100 LCD Monitor Replacement: 手順 2、 3の画像 2 Acer Aspire 5100 LCD Monitor Replacement: 手順 2、 3の画像 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 LCD Monitor Replacement: 手順 3、 1の画像 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  4. Acer Aspire 5100 LCD Monitor Replacement, LCD Monitor: 手順 4、 1の画像 1
    • Remove the two screws from each corner beneath the LCD screen.
  5. Acer Aspire 5100 LCD Monitor Replacement: 手順 5、 2の画像 1 Acer Aspire 5100 LCD Monitor Replacement: 手順 5、 2の画像 2
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  6. Acer Aspire 5100 LCD Monitor Replacement: 手順 6、 2の画像 1 Acer Aspire 5100 LCD Monitor Replacement: 手順 6、 2の画像 2
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  7. Acer Aspire 5100 LCD Monitor Replacement: 手順 7、 1の画像 1
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  8. Acer Aspire 5100 LCD Monitor Replacement: 手順 8、 1の画像 1
    • Lift up the monitor to detach it.
終わりに
8 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Brad Rollinson
メンバー登録日: 09/29/10
1,113 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 14-39, Forte Fall 2010 Cal Poly, Team 14-39, Forte Fall 2010人のメンバー
CPSU-FORTE-F10S14G39
5 メンバー
10のガイドは作成済み
コメント 1 件
There are 2 screws at the back corners on the bottom cover that are holding the screen down. They need to be removed in order for the screen to be lifted.
Kar Wong - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 9
今までの合計 15,440
