この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Over time, your Acer Aspire 5100 laptop’s fan may stop working. Laptops without working fans may overheat, damaging internal hardware such as the CPU, hard drive, and motherboard. You may have a broken fan if your laptop regularly feels hot or crashes, your fan makes abnormal or no noise, or your vents lack airflow. If these problems occur, you will need a replacement fan to keep your laptop regulated and running smoothly.
This guide will help you replace your broken fan in four simple steps. Before starting, be sure to unplug your laptop and remove the battery for your personal safety.
必要な工具と部品
To reassemble your device, follow the previous instructions in reverse order as follows:
1. Connect the replacement fan to the motherboard.
2. Screw the fan into place.
3. Screw in the back panel above the fan.
4. Return the battery.
4 の人々がこのガイドを完成させました。
