メインコンテンツにスキップ
Acer Aspire 5 A515-43-R19L RAM Replacement
必要な工具と部品
  1. Acer Aspire 5 A515-43-R19L RAM Replacement, RAM: 手順 1、 1の画像 1
    • Place your device with the top facing down.
    • Make sure the primary exhaust is facing away from you.
  2. Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 2、 2の画像 1 Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 2、 2の画像 2
    • Remove the nine screws from the bottom of the laptop using a Phillips #1 screwdriver.
  3. Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 3、 3の画像 1 Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 3、 3の画像 2 Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 3、 3の画像 3
    • Use a prying tool to separate the case from the laptop.
    • As you reach the exhausts and screen hinges, be especially careful. Too much force may cause unforeseen damage.
    • Potential device damage: Avoid pushing too far into the device during this process, as you may apply unnecessary force to the sensitive internals.
  4. Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 4、 3の画像 1 Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 4、 3の画像 2 Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 4、 3の画像 3
    • With any step working on the device's internals, keep direct contact with any components to a minimum. This is doubly true for your exposed skin.
    • While this step is not necessary, it is common practice to reduce the chances of things going wrong. (i.e "bricking" your device).
    • Use an opening tool to detach the battery connector from the motherboard.
  5. Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 5、 3の画像 1 Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 5、 3の画像 2 Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 5、 3の画像 3
    • You'll find RAM slots north of the battery connection point and to the right of the copper pieces.
    • Lightly grip and push both sides of the RAM housing in opposite directions until the RAM pops up from the slot at an angle.
    • Pull the RAM free from the slot.
  6. Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 6、 3の画像 1 Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 6、 3の画像 2 Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 6、 3の画像 3
    • Align your RAM's DIMMs so the shorter side slots into the shorter space and the larger side slots into the larger space.
    • Insert the RAM at an angle.
    • Press down on the stick until the bearings on both sides click into place.
  7. Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 7、 2の画像 1 Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 7、 2の画像 2
    • Reconnect the battery to the motherboard.
  8. Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 8、 2の画像 1 Acer Aspire 5 A515-43-R19L RAM Replacement: 手順 8、 2の画像 2
    • Place the shell back onto the laptop, clicking each corner and side into place.
    • Screw the shell back onto the laptop.
ゴール
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Troy Rana
メンバー登録日: 10/25/23
229 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 4-18, Kershman Fall 2023 CSU Los Angeles, Team 4-18, Kershman Fall 2023人のメンバー
CSULA-KERSHMAN-F23S4G18
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 31
過去 30 日: 121
今までの合計 909
