メインコンテンツにスキップ
Acer Aspire 4743-6481 Screen Replacement
必要な工具と部品
  1. Acer Aspire 4743-6481 Screen Replacement, Battery: 手順 1、 1の画像 1
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Screen Replacement: 手順 2、 1の画像 1
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Screen Replacement: 手順 3、 1の画像 1
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Screen Replacement, Screen: 手順 4、 1の画像 1
    • Position the laptop so you have a clear view of the front of the screen.
    • Remove the two screw covers at the bottom sides of the screen casing using a flat tool.
    • Remove the two 5.0 mm Phillips screws. They will be directly underneath the screw covers.
  5. Acer Aspire 4743-6481 Screen Replacement: 手順 5、 1の画像 1
    • Use a flat tool, to pry open along every side of the front casing of the screen.
    • It will require a small amount of force to grudge open. Make sure every side of the casing is loose before removing it.
    • You should use a metal pry tool only if you are unsuccessful with a plastic one. The metal tool could cause damage to your device.
  6. Acer Aspire 4743-6481 Screen Replacement: 手順 6、 1の画像 1
    • Remove the front casing.
    • Remove the four 5.0 mm Phillips screws located next to every corner of the screen.
  7. Acer Aspire 4743-6481 Screen Replacement: 手順 7、 1の画像 1
    • After removing the screws, gently place the screen on top of the keyboard.
    • Do not attempt to remove the screen yet since it is not fully disconnected from the laptop.
    • You may use a piece of cloth or similar material beneath the new screen to avoid scratching it with the other surface.
  8. Acer Aspire 4743-6481 Screen Replacement: 手順 8、 3の画像 1 Acer Aspire 4743-6481 Screen Replacement: 手順 8、 3の画像 2 Acer Aspire 4743-6481 Screen Replacement: 手順 8、 3の画像 3
    • Gently remove the tape that covers the connector cable, as highlighted in the first picture.
    • With a flat tool, gently disconnect the connector cable from the damaged screen.
  9. Acer Aspire 4743-6481 Screen Replacement: 手順 9、 1の画像 1
    • Remove the four remaining 3.5 mm Phillips screws from the screen piece.
    • There will be two screws on each side, one on the bottom and another on the top.
  10. Acer Aspire 4743-6481 Screen Replacement: 手順 10、 1の画像 1
    • The screen can be easily removed from its frame now.
終わりに
To reassemble your device, carefully follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Juan Seijas
メンバー登録日: 02/15/17
199 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S5-G1, Lacy Spring 2017 USF Tampa, Team S5-G1, Lacy Spring 2017人のメンバー
USFT-LACY-S17S5G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 1,718
