はじめに
This guide will show you how to replace the keyboard of an Acer Aspire 4520-5464 laptop. The keyboard is used to type and use commands on the laptop.
必要な工具と部品
Shut down the computer and disconnect all external devices and cables.
Flip the computer over.
Remove the five 1mm Phillips #1 screws located inside of the battery compartment.
Remove the three 2mm Phillips #1 screws located at the top of the case's perimeter.
To reassemble your device, follow these instructions in reverse order using your new keyboard.
ある他の人がこのガイドを完成しました。
