メインコンテンツにスキップ
Acer Aspire 4520-5464 Keyboard Replacement
必要な工具と部品
  1. Acer Aspire 4520-5464 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Keyboard Replacement: 手順 2、 2の画像 1 Acer Aspire 4520-5464 Keyboard Replacement: 手順 2、 2の画像 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Keyboard Replacement: 手順 3、 1の画像 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Keyboard Replacement, Keyboard: 手順 4、 1の画像 1
    • Remove the five 1mm Phillips #1 screws located inside of the battery compartment.
    • Remove the three 2mm Phillips #1 screws located at the top of the case's perimeter.
  5. Acer Aspire 4520-5464 Keyboard Replacement: 手順 5、 2の画像 1 Acer Aspire 4520-5464 Keyboard Replacement: 手順 5、 2の画像 2
    • Remove the gray plastic section located above the keyboard using the prying tool.
    • Lift off of the keyboard.
  6. Acer Aspire 4520-5464 Keyboard Replacement: 手順 6、 2の画像 1 Acer Aspire 4520-5464 Keyboard Replacement: 手順 6、 2の画像 2
    • Take hold of the keyboard behind the function keys and lift gently.
    • Do not completely separate the keyboard from the laptop.
  7. Acer Aspire 4520-5464 Keyboard Replacement: 手順 7、 2の画像 1 Acer Aspire 4520-5464 Keyboard Replacement: 手順 7、 2の画像 2
    • Lift up the black locking tab located where the keyboard is attached to the laptop.
    • Pull the keyboard cable towards the trackpad and remove the keyboard.
終わりに
To reassemble your device, follow these instructions in reverse order using your new keyboard.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Hunter Gilcrease
メンバー登録日: 09/21/17
367 ポイント
3のガイドは作成済み
チーム
Washington State, Team S5-G117, Phelps-Hillen Fall 2017 Washington State, Team S5-G117, Phelps-Hillen Fall 2017人のメンバー
WSU-PHELPS-HILLEN-F17S5G117
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 15
今までの合計 605
