メインコンテンツにスキップ
Acer Aspire 3003WLCi RAM Replacement
必要な工具と部品
  1. Acer Aspire 3003WLCi RAM Replacement, Battery: 手順 1、 1の画像 1
    • Turn the Acer Aspire 3003WLCi so that the bottom of the laptop is facing up. Orient it so that the battery is on your left.
  2. Acer Aspire 3003WLCi RAM Replacement: 手順 2、 3の画像 1 Acer Aspire 3003WLCi RAM Replacement: 手順 2、 3の画像 2 Acer Aspire 3003WLCi RAM Replacement: 手順 2、 3の画像 3
    • There will be two switches on the back of the laptop: one at the top of the battery, and one at the bottom.
    • Shift the bottom switch into an upward position in order to unlock the battery.
    • To unlock the upper switch, forcefully push the switch up and hold it in this position.
  3. Acer Aspire 3003WLCi RAM Replacement: 手順 3、 2の画像 1 Acer Aspire 3003WLCi RAM Replacement: 手順 3、 2の画像 2
    • While holding the upper switch in the upward position, remove the battery by pulling it out to the left.
    • You may need to be a bit forceful when pulling the battery to the left if it hasn't been removed before.
    • You have to maintain pulling the upper switch upwards, or the battery will not come out.
  4. Acer Aspire 3003WLCi RAM Replacement, RAM: 手順 4、 1の画像 1
    • The panel in the center of your device is the panel you will remove to replace the RAM.
  5. Acer Aspire 3003WLCi RAM Replacement: 手順 5、 2の画像 1 Acer Aspire 3003WLCi RAM Replacement: 手順 5、 2の画像 2
    • Using a Phillips #0 screwdriver, unscrew both 5mm captive screws on this panel.
    • The screws will not fully come out of the panel. This is intentional by the manufacturer.
  6. Acer Aspire 3003WLCi RAM Replacement: 手順 6、 3の画像 1 Acer Aspire 3003WLCi RAM Replacement: 手順 6、 3の画像 2 Acer Aspire 3003WLCi RAM Replacement: 手順 6、 3の画像 3
    • Stick the tip of a spudger into the seam between the panel and the laptop body, on the side of the panel with the screws.
    • Use the spudger to pry up this side of the panel.
    • Grab the lifted side of the panel with your remaining hand and lift. You should hear a popping sound as the panel comes off completely.
    • During reassembly, you won't need the spudger. You'll simply need to replace and push on the panel until you hear it click back into place.
  7. Acer Aspire 3003WLCi RAM Replacement: 手順 7、 2の画像 1 Acer Aspire 3003WLCi RAM Replacement: 手順 7、 2の画像 2
    • Orient the laptop so that the battery is closest to you. The RAM slots are at the top of the laptop, and each stick of RAM has two tabs to hold it in its slot.
    • Remove both sticks of RAM. To do this, use both thumbs to push the tabs away from the desired stick of RAM. The stick should pop up at an angle when the tabs are pushed far enough.
  8. Acer Aspire 3003WLCi RAM Replacement: 手順 8、 2の画像 1 Acer Aspire 3003WLCi RAM Replacement: 手順 8、 2の画像 2
    • Use your thumbs and forefingers to pull the RAM out of its socket. Be sure to maintain the angle.
    • Repeat steps 4 and 5 for the second stick of RAM that lies underneath the first.
終わりに
作成者
3人の作成者と共同で作成されました。
Tristin Viale
メンバー登録日: 03/25/19
675 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G2, Bailey Spring 2019 UMass Dartmouth, Team S2-G2, Bailey Spring 2019人のメンバー
UMASSD-BAILEY-S19S2G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 7
過去 30 日: 11
今までの合計 737
