メインコンテンツにスキップ
Acer Aspire 3000 Wireless Card Replacement
必要な工具と部品
  1. Acer Aspire 3000 Wireless Card Replacement, Battery: 手順 1、 1の画像 1
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Wireless Card Replacement: 手順 2、 2の画像 1 Acer Aspire 3000 Wireless Card Replacement: 手順 2、 2の画像 2
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Wireless Card Replacement: 手順 3、 2の画像 1 Acer Aspire 3000 Wireless Card Replacement: 手順 3、 2の画像 2
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 Wireless Card Replacement, Wireless Card: 手順 4、 1の画像 1
    • Remove the two 4.6 mm Phillips #1 screws on the lower edge of the laptop case.
  5. Acer Aspire 3000 Wireless Card Replacement: 手順 5、 1の画像 1
    • Pop the three side tabs out of the back case.
  6. Acer Aspire 3000 Wireless Card Replacement: 手順 6、 1の画像 1
    • Remove the panel that covers the graphics card.
  7. Acer Aspire 3000 Wireless Card Replacement: 手順 7、 1の画像 1
    • Remove the black and white cables attached to the graphics card.
    • Be careful to lift vertically as to not mess up either part of the connectors.
  8. Acer Aspire 3000 Wireless Card Replacement: 手順 8、 1の画像 1
    • Push the white flanges on either side of the graphics card out.
    • The card should lift on its own slightly out of the case.
  9. Acer Aspire 3000 Wireless Card Replacement: 手順 9、 1の画像 1
    • Remove the card by lifting up and away from the edge that has all of the contacts on it.
終わりに
作成者
4人の作成者と共同で作成されました。
Lykia Harper
メンバー登録日: 10/29/16
258 ポイント
2のガイドは作成済み
チーム
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016人のメンバー
BU-WILLIAMS-F16S4G2
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 956
