メインコンテンツにスキップ
Acer Aspire 3000 Keyboard Replacement
必要な工具と部品
  1. Acer Aspire 3000 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Keyboard Replacement: 手順 2、 2の画像 1 Acer Aspire 3000 Keyboard Replacement: 手順 2、 2の画像 2
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Keyboard Replacement: 手順 3、 2の画像 1 Acer Aspire 3000 Keyboard Replacement: 手順 3、 2の画像 2
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 Keyboard Replacement, Keyboard: 手順 4、 1の画像 1
    • Lift the laptop to be on its edge, with the bottom of the screen in the air.
  5. Acer Aspire 3000 Keyboard Replacement: 手順 5、 1の画像 1
    • Remove the three 4.6 mm Phillips #1 screws that are on this edge.
  6. Acer Aspire 3000 Keyboard Replacement: 手順 6、 2の画像 1 Acer Aspire 3000 Keyboard Replacement: 手順 6、 2の画像 2
    • Wedge a spudger into the latch on the right side.
    • Open the lid completely to facilitate removal.
    • Pull the handle of the spudger towards you to pop the first of the tabs that hold this piece in place.
    • Starting from right to left, pop the remaining tabs by lifting up on the panel and rotating the panel to the left.
  7. Acer Aspire 3000 Keyboard Replacement: 手順 7、 1の画像 1
    • Unscrew the two 4.6 mm Phillips #1 screws.
  8. Acer Aspire 3000 Keyboard Replacement: 手順 8、 1の画像 1
    • Gently lift the top edge of the keyboard out of its place.
    • Do not completely remove the keyboard as there is still a ribbon cable connecting it to the device.
  9. Acer Aspire 3000 Keyboard Replacement: 手順 9、 1の画像 1
    • Lift the ZIF connector's black retaining flap. Then gently slide the ribbon cable out.
    • Remove the keyboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Lykia Harper
メンバー登録日: 10/29/16
258 ポイント
2のガイドは作成済み
チーム
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016人のメンバー
BU-WILLIAMS-F16S4G2
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 783
