メインコンテンツにスキップ
Acer AL1916 Power Supply Board Replacement
必要な工具と部品
  1. Acer AL1916 Power Supply Board Replacement, Stand: 手順 1、 1の画像 1
    • Lay the monitor on a flat surface so that the back is facing up.
  2. Acer AL1916 Power Supply Board Replacement: 手順 2、 2の画像 1 Acer AL1916 Power Supply Board Replacement: 手順 2、 2の画像 2
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
  3. Acer AL1916 Power Supply Board Replacement: 手順 3、 2の画像 1 Acer AL1916 Power Supply Board Replacement: 手順 3、 2の画像 2
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
  4. Acer AL1916 Power Supply Board Replacement, Outer Case: 手順 4、 2の画像 1 Acer AL1916 Power Supply Board Replacement, Outer Case: 手順 4、 2の画像 2
    • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
  5. Acer AL1916 Power Supply Board Replacement: 手順 5、 3の画像 1 Acer AL1916 Power Supply Board Replacement: 手順 5、 3の画像 2 Acer AL1916 Power Supply Board Replacement: 手順 5、 3の画像 3
    • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
    • Tilt the plastic opening tool up to separate the back cover from the display bezel.
    • Continue around the perimeter of the monitor until the display bezel comes off.
    • A reasonable amount of force is necessary to detach the back cover from the display bezel.
  6. Acer AL1916 Power Supply Board Replacement: 手順 6、 2の画像 1 Acer AL1916 Power Supply Board Replacement: 手順 6、 2の画像 2
    • Reposition the monitor so that the back is facing up.
    • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
    • Lift the back cover up.
  7. Acer AL1916 Power Supply Board Replacement, EMI Shield: 手順 7、 2の画像 1 Acer AL1916 Power Supply Board Replacement, EMI Shield: 手順 7、 2の画像 2
    • Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
  8. Acer AL1916 Power Supply Board Replacement: 手順 8、 2の画像 1 Acer AL1916 Power Supply Board Replacement: 手順 8、 2の画像 2
    • Using a nut driver (or if necessary, needle-nose pliers), remove the two nuts on either side of the VGA input.
  9. Acer AL1916 Power Supply Board Replacement: 手順 9、 3の画像 1 Acer AL1916 Power Supply Board Replacement: 手順 9、 3の画像 2 Acer AL1916 Power Supply Board Replacement: 手順 9、 3の画像 3
    • Grab the metal casing by the sides and slide it down towards the bottom of the monitor.
    • Lift up to remove the metal casing.
    • Beware, metal casing is sharp!
  10. Acer AL1916 Power Supply Board Replacement, Power Supply Board: 手順 10、 2の画像 1 Acer AL1916 Power Supply Board Replacement, Power Supply Board: 手順 10、 2の画像 2
    • Remove the three 7.5 mm Phillips #2 screws and one silver 8.3 mm Phillips #2 screw from the power supply.
  11. Acer AL1916 Power Supply Board Replacement: 手順 11、 3の画像 1 Acer AL1916 Power Supply Board Replacement: 手順 11、 3の画像 2 Acer AL1916 Power Supply Board Replacement: 手順 11、 3の画像 3
    • Remove the two pieces of yellow tape on the left side of the power supply.
  12. Acer AL1916 Power Supply Board Replacement: 手順 12、 2の画像 1 Acer AL1916 Power Supply Board Replacement: 手順 12、 2の画像 2
    • Remove the four little white clips located underneath the tape by lifting up on their left side.
    • It would be a good idea to take a picture of the way these connect before removing them.
  13. Acer AL1916 Power Supply Board Replacement: 手順 13、 3の画像 1 Acer AL1916 Power Supply Board Replacement: 手順 13、 3の画像 2 Acer AL1916 Power Supply Board Replacement: 手順 13、 3の画像 3
    • With the needle-nose pliers, remove the four display connectors by pulling them away from the power supply.
  14. Acer AL1916 Power Supply Board Replacement: 手順 14、 2の画像 1 Acer AL1916 Power Supply Board Replacement: 手順 14、 2の画像 2
    • Pull up and remove the white plug that connects the blue and brown wires to the power supply.
  15. Acer AL1916 Power Supply Board Replacement: 手順 15、 3の画像 1 Acer AL1916 Power Supply Board Replacement: 手順 15、 3の画像 2 Acer AL1916 Power Supply Board Replacement: 手順 15、 3の画像 3
    • Remove the rainbow-colored power cable by pulling it straight up.
  16. Acer AL1916 Power Supply Board Replacement: 手順 16、 3の画像 1 Acer AL1916 Power Supply Board Replacement: 手順 16、 3の画像 2 Acer AL1916 Power Supply Board Replacement: 手順 16、 3の画像 3
    • Using the needle nose pliers, pinch the white clip so that it can fit through the hole in the power supply.
    • Lift up the power supply and remove it from the rest of the monitor.
終わりに
7 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Keith
メンバー登録日: 10/06/11
351 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 20-26, Maness Fall 2011 Cal Poly, Team 20-26, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S20G26
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 28
今までの合計 15,736
