はじめに
Replacing your display will give you a fresh new screen when your old one is not functioning properly.
必要な工具と部品
Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
Remove the three gold 7.5 mm Phillips #2 screws and one silver 8.3 mm Phillips #2 screw from the power supply.
終わりに
6 の人々がこのガイドを完成させました。
