メインコンテンツにスキップ
Accu-Chek Guide Diabetes Meter Battery Replacement
必要な工具と部品
  1. Accu-Chek Guide Diabetes Meter Battery Replacement, Battery: 手順 1、 2の画像 1 Accu-Chek Guide Diabetes Meter Battery Replacement, Battery: 手順 1、 2の画像 2
    • Press the OK button to make sure the meter is turned off.
    • Turn the device over and look for the latch on the back of the battery compartment.
  2. Accu-Chek Guide Diabetes Meter Battery Replacement: 手順 2、 2の画像 1 Accu-Chek Guide Diabetes Meter Battery Replacement: 手順 2、 2の画像 2
    • Push the latch toward the battery door to release the lock, then lift the battery door to remove it.
  3. Accu-Chek Guide Diabetes Meter Battery Replacement: 手順 3、 3の画像 1 Accu-Chek Guide Diabetes Meter Battery Replacement: 手順 3、 3の画像 2 Accu-Chek Guide Diabetes Meter Battery Replacement: 手順 3、 3の画像 3
    • Use a plastic spudger near the middle right side of the top 3V battery to pry it from the battery holder.
    • Press down on the middle of the battery holder to eject the bottom battery.
  4. Accu-Chek Guide Diabetes Meter Battery Replacement: 手順 4、 2の画像 1 Accu-Chek Guide Diabetes Meter Battery Replacement: 手順 4、 2の画像 2
    • Slide the new 3V battery in the top slot, then press down to secure it in place.
    • Replace the 3V battery in the bottom slot.
    • The plus sign on the 3V batteries should face down when placed in each slot.
  5. Accu-Chek Guide Diabetes Meter Battery Replacement: 手順 5、 2の画像 1 Accu-Chek Guide Diabetes Meter Battery Replacement: 手順 5、 2の画像 2
    • Carefully slide the cover back into place and push it down to lock it securely.
  6. Accu-Chek Guide Diabetes Meter Battery Replacement: 手順 6、 2の画像 1 Accu-Chek Guide Diabetes Meter Battery Replacement: 手順 6、 2の画像 2
    • Press and hold the OK button for 5-7 seconds to reactivate the meter.
    • Observe the display to confirm the successful reactivation before using the Accu-Chek Guide Diabetes Meter.
    • If you are reactivating the meter after a period of inactivity, it may take a few extra seconds to initialize.
終わりに
With the successful replacement of the batteries and reactivation of the Accu-Chek Guide Meter, the device is fully operational, ready to provide accurate and reliable readings.
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Syed Ahmed
メンバー登録日: 02/03/24
187 ポイント
1ガイドが承認済み
チーム
York University, Team M-1, Allen Winter 2024 York University, Team M-1, Allen Winter 2024人のメンバー
YORK-ALLEN-W24SMG1
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 22
今までの合計 183
