この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will require you to disassemble the rear and side panels of the printer in order to access the circuit board.
必要な工具と部品
Remove the top hinged panel by taking out the pins at the bottom of this panel.
Remove the front panel by gently freeing the holes on the panel from the pegs attached to the main printer body one at a time. Make sure to remove the entire front panel, not just the flap on the paper tray.
3 の人々がこのガイドを完成させました。
