メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Accessing Apple Cinema Display M8149 Control Boards
必要な工具と部品
  1. Accessing Apple Cinema Display M8149 Control Boards, Control Boards: 手順 1、 3の画像 1 Accessing Apple Cinema Display M8149 Control Boards, Control Boards: 手順 1、 3の画像 2 Accessing Apple Cinema Display M8149 Control Boards, Control Boards: 手順 1、 3の画像 3
    • Before starting, make sure the display is unplugged.
    • Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
    • Remove the three screws (9.52 x 4.43mm) that connect the back foot to the hinge using the Hex Key.
    • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
  2. Accessing Apple Cinema Display M8149 Control Boards: 手順 2、 3の画像 1 Accessing Apple Cinema Display M8149 Control Boards: 手順 2、 3の画像 2 Accessing Apple Cinema Display M8149 Control Boards: 手順 2、 3の画像 3
    • Remove the eighteen (5.25 x 4.43 mm) screws around the edge of the backplate using the Hex key.
    • Disconnect the small white connector leading to the display's Power button.
    • Gently lift the backplate off of the display. Completely remove the backplate and set it aside.
  3. Accessing Apple Cinema Display M8149 Control Boards: 手順 3、 2の画像 1 Accessing Apple Cinema Display M8149 Control Boards: 手順 3、 2の画像 2
    • Use a Phillips #2 screwdriver to remove the four (9.52 x 3.43 mm) screws on the outer rim of the metal cover.
    • Next, remove the four cover (11.91 x 2.89 mm) screws located at the corners of the metal cover using the Phillips #2 screwdriver.
  4. Accessing Apple Cinema Display M8149 Control Boards: 手順 4、 3の画像 1 Accessing Apple Cinema Display M8149 Control Boards: 手順 4、 3の画像 2 Accessing Apple Cinema Display M8149 Control Boards: 手順 4、 3の画像 3
    • Unplug the large brown plug in the center-right, that connects the control board to the rest of the display.
    • Unplug the blue and gray plug on the right side of the control board. Repeat with the left side.
  5. Accessing Apple Cinema Display M8149 Control Boards: 手順 5、 2の画像 1 Accessing Apple Cinema Display M8149 Control Boards: 手順 5、 2の画像 2
    • Gently lift the large metal cover which spans across the back of the whole display.
終わりに
3 の人々がこのガイドを完成させました。
作成者
15人の作成者と共同で作成されました。
Brett Murphy
メンバー登録日: 04/01/11
197 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 10-41, Forte Spring 2011 Cal Poly, Team 10-41, Forte Spring 2011人のメンバー
CPSU-FORTE-S11S10G41
5 メンバー
18のガイドは作成済み
1件のガイドコメント
thank you for this guide. my 22" adc didn't want to start up. after following this guide, it now works with my G4. thank you
thereddrag0n - 返信 共有
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 16
過去 30 日: 62
今までの合計 6,192
