はじめに
The front cover quickly suffers a break on the narrow bars around the key field, which at some point can no longer be repaired with adhesive tape or glue. I'm trying to 3d print the top shell and replace it. Someone on Thingivers provided templates for printing.
The front can also be found on Ebay under the keyword “FritzFon C5 front”
必要な工具と部品
Loosen the back panel using your fingernail/ guitar pick or a spudger.
Slide the pick all around the housing until the back panel comes off.
Once it's off simply remove the battery from the housing.
Loosen the 8 T5 screws, and set them aside.
The upper shell / front of the housing consists of filigree bars around the keypad, so special care is required here. In my case, some of these were already broken.
Move the opening pick / spudger around the case, lifting off the tabs (orange) with a flat screwdriver. This is done through the corresponding openings in the middle part of the housing (green).
The circuit board can then be easily removed together with the keypad.
Replace the parts to be repaired and screw them back together.
Loudspeaker (yellow) and screen protector (green) are glued on and can be easily lifted out with a flat screwdriver.
A transparent piece of plastic (light blue), which was probably used to align the loudspeaker, was no longer needed, nor was I able to take over the piece of fabric (red) in front of the loudspeaker.
The keypad got hooked in a few places, so I had to rework the associated openings with a file.
Put everything back together in reverse order - make sure that the buttons do not get stuck.
Reverse the steps to reassemble your device.
6 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
12 件のコメント
I can’t say without knowing your question/problem.
Hallo - da kann ich leider nichts zu sagen, da ich meine Oberschale selbst gedruckt habe. Ich habe auch keine Erfahrung wie es ist, wenn man einen solchen Druck in Auftrag gibt - falls Sie da Erfahrung sammeln, fände ich eine kurze Info auch interessant. Viel Erfolg!
Hallöle, kannst du die 3D zur Verfügung stellen.
Grüße
M O -
