メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
AUX-208P1 Electric Kettle Temperature Controller Replacement
必要な工具と部品
  1. AUX-208P1 Electric Kettle Temperature Controller Replacement, Temperature Controller: 手順 1、 2の画像 1 AUX-208P1 Electric Kettle Temperature Controller Replacement, Temperature Controller: 手順 1、 2の画像 2
    • Clean all the dirt on the bottom of the electric kettle.
  2. AUX-208P1 Electric Kettle Temperature Controller Replacement: 手順 2、 2の画像 1 AUX-208P1 Electric Kettle Temperature Controller Replacement: 手順 2、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the three 19 mm screws at the bottom of the electric kettle.
    • Remove the base of the electric kettle.
    • Remove the LED indicator buckled on the base.
  3. AUX-208P1 Electric Kettle Temperature Controller Replacement: 手順 3、 2の画像 1 AUX-208P1 Electric Kettle Temperature Controller Replacement: 手順 3、 2の画像 2
    • Use combination pliers to clamp the connection between the electric kettle line and the old temperature controller to create a gap, and pull it off.
    • Don't use too much force to avoid damage to the line!
  4. AUX-208P1 Electric Kettle Temperature Controller Replacement: 手順 4、 1の画像 1
    • Use combination pliers to remove the nuts holding down the old temperature controller.
  5. AUX-208P1 Electric Kettle Temperature Controller Replacement: 手順 5、 2の画像 1 AUX-208P1 Electric Kettle Temperature Controller Replacement: 手順 5、 2の画像 2
    • Remove the broken temperature controller.
    • Clean the bottom of the kettle to remove any dust or debris buildup.
  6. AUX-208P1 Electric Kettle Temperature Controller Replacement: 手順 6、 1の画像 1
    • Align the socket on the bottom of the new temperature controller with the protrusion on the bottom of the electric kettle to assemble.
  7. AUX-208P1 Electric Kettle Temperature Controller Replacement: 手順 7、 1の画像 1
    • Use combination pliers to reinstall the nuts holding down the temperature controller.
  8. AUX-208P1 Electric Kettle Temperature Controller Replacement: 手順 8、 1の画像 1
    • Fasten the electric kettle circuit to the contact reed of the new temperature controller.
    • Gently pull the interface to ensure a firm installation.
  9. AUX-208P1 Electric Kettle Temperature Controller Replacement: 手順 9、 2の画像 1 AUX-208P1 Electric Kettle Temperature Controller Replacement: 手順 9、 2の画像 2
    • Re-buckle the removed LED indicator back to the base.
    • Buckle the base back to the bottom of the electric kettle.
    • Use a Phillips #0 screwdriver to three 19 mm screws on the bottom of the kettle.
終わりに
重新组装设备时,请依次相反的拆卸顺序。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
SHAN HUANG
メンバー登録日: 01/13/21
193 ポイント
2のガイドは作成済み
チーム
York University, Team S1-G30, O'Regan Winter 2021 York University, Team S1-G30, O'Regan Winter 2021人のメンバー
YORK-O'REGAN-W21S1G30
1 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 20
過去 30 日: 92
今までの合計 3,068
