はじめに
Use this keypad replacement guide if buttons are missing or damaged. A potential hazard would be affecting the motherboard through the charge that you internally carry, therefore you should use the anti-static wrist strap to prevent this. References to the other guides will be used.
必要な工具と部品
Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
もう少しです!
終わりに
