メインコンテンツにスキップ
ATT CL4940 Internal Microphone Replacement
必要な工具と部品
  1. ATT CL4940 Internal Microphone Replacement, Internal Microphone: 手順 1、 2の画像 1 ATT CL4940 Internal Microphone Replacement, Internal Microphone: 手順 1、 2の画像 2
    • Unplug your device before beginning disassembly.
    • Remove the phone line and the power cord from the back of the device.
    • Remove the phone cable from the side of the device.
  2. ATT CL4940 Internal Microphone Replacement: 手順 2、 1の画像 1
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Microphone Replacement: 手順 3、 3の画像 1 ATT CL4940 Internal Microphone Replacement: 手順 3、 3の画像 2 ATT CL4940 Internal Microphone Replacement: 手順 3、 3の画像 3
    • Starting from the bottom of the device, (using a metal spudger) separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Microphone Replacement: 手順 4、 1の画像 1
    • Using wire cutters, sever both the red and the black wires connected to the microphone.
    • To remove the microphone from the device, gently wiggle it while pulling it apart.
終わりに
作成者
3人の作成者と共同で作成されました。
Charles Moore
メンバー登録日: 02/16/16
201 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 2-2, Harley Spring 2016 IUPUI, Team 2-2, Harley Spring 2016人のメンバー
IUPUI-HARLEY-S16S2G2
4 メンバー
8のガイドは作成済み
コメント 1 件
I'd rather install a new microphone instead of just reinstalling the old one.
Is there a link to where a new microphone can be purchased?
rpoland - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 19
今までの合計 647
